Finally figured out how to disable that annoying chime for trips in the neighborhood.
Unbolt the front driver's seat 4 14mm bolts.
Disconnect negative terminal from the battery.
Rotate the drivers seat away from the center console so you have access to the buckle.
There should be two "wires" going into the bottom of the buckle.
Cut the wire in-between the buckle and the seat NOT the wire in-between the seat and the console.
Make sure the two strands inside the wire you cut are not touching.
Reassemble and enjoy the silence of a chimeless trip.
Obviously ALWAYS wear your seatbelt.
