<_< I am having problems with my dashboard lights and high beams. I don't have any. I have checked my fuses and relays but they all appear fine -- I have running lights and low beams so it doesn't appear to be an electrical problem. Any one else experience this unique situation?
sounds like a problem with the multifunction switch.
does the high beam indicator go on when the switch is in h-beam position ??
does the h-beam go on when you pull up to flash the h-beams ??
I'm having the same problems but my tail light don't work either unless i step on the brakes than all my light come on.
