1 - 1 of 1 Posts
Car start with no problem
The speedo, odo, tach, temp and fuel gauges are not working. Shifter stuck in park (must use manual bypass button to put in drive).
When car is in ON position, nothing shows in the cluster, cluster is dead... When started, I see no problem with engine, headlights work, brake lights also works, infotainment works fine, I use a slim metal to press a hole close to Gear lever
Rest work fine.
can someone help me. if it is a fuse, I have no clue witch one it is... please help me on this, very important
1 - 1 of 1 Posts
