1 - 10 of 10 Posts
Hi
I need to change bulbs in dashboard but I do not know how to remove the cluster dashboard - I fear damaging using wrong technic. There is a post about this in the forum (can't remebember where) but the method described there did not work.
Thanks
It's been a while since I worked on an Atoz but from memory the trim around the instrument cluster is secured by clips and just prys off. That should expose the cluster securing screws and once they're removed the cluster should just lift out of the opening.
Hi Autospark
Yep it worked without damaging the whole cluster he.
It is strange that all the bulbs in dahsboard seems ok( checked with ohmeter) and fuses ok but no light
Other lights on panel (facia near radio and others) are ok
Need to trace the lines and find out.
Thanks again
He he
No it did not happen - all bulbs are ok.
The whole fixing and investigation of this car took about 4 weeks, about $20 in spareparts and help from you Autospark and Desmaui .
The reward is fine running engine in almost non rusted car.
Thanks agin Autospark and Desmaui
Bernhard
No rust on mine too, even if it is always outside since 2001.
Yes, probably this is why it's not under the uk's weather!! :)
Thanks to you for the help!
Hi I am facing the same issue my odometer bulbs are ok can you guide me to resolve this problem.
1 - 10 of 10 Posts
