· Registered
Just sorted my cylinder head gasket only to have the cylinder liner go boom, got the engine out and stripped now its away to get refurbed, while the engine is out i noticed quite a bit of movement in the flywheel so going to replace that and the clutch, any advice on where to get a good deal on one in the UK
· Registered
Hi not quite sure who’s the best value at the moment shop around a bit.Sure you will get plenty of replies. You could do me a big favour seems you have stripped it down.There is a hydraulic pipe which runs from the Turbo to the engine block on the other side where a banjo bolt connects it to the block.I have just finished putting mine back together and I can’t find the banjo bolt...Do you think you could measure the size and the thread so that I can order a new one .A photo would be great as well
Regards
Paul
