Hey guys, I need a little help. I ended up curbing my rim a little bit after a long work day and a long drive from NJ to Pittsburgh. Does anyone know the exact paint spec for the rims?
Must be nice. My Chrysler 300M came with a full size spare mounted on a chrome alloy rim that matches the rest of the car. OTOH, my Santa Fe came with the infamous "Space Saver Spare" donut on a cheap steel rim. I swapped that out for another cheap rim with a 16" tire that matched the OD of the 18" tires it came with. When I drive off the paved roads up in the mountains, if I blow a tire, there's a good chance that the little "Space Saver" would last about 30 seconds.You could always swap the spare for the damaged wheel if the sight of it is bothering you that much
