My '12 SE cruise works fine 60% of the time, but sometimes it won't set, sometimes it won't cancel using the button on the steering wheel, and sometimes it won't slow or accelerate using the buttons. Has anyone else had this issue?
I had the same issue until tonight. my friend and i Installed OEM fog lights and i have to take the steering wheel off to change the light stalk. while the steering wheel was off i wiggled the wires around that connect to the cruise control buttons and made sure the connector was on tight and now it seems to be working correctly.
Thanks. Next time I take it in, I will have them check the connections. It's an intermittent issue, so hopefully they can get it straightened out. Sometimes i will turn off the cruise, then a few minutes later I will turn it on and it works fine.
