1 - 8 of 8 Posts
43000-22650 is a elantra 5 speed to 1999
is there anyway to cross ref to a 2000 accent 22753
dealer is no help other than giving me the 2000 #
I've never heard of such part numbers for trans on Hyundai's.... more like F4A32, A4BF1 or A4BF3 for '00 Elantra.... That's just one example. Where did you find the trans ID numbers you have now?
These are hyundai #s for each trans.put either # in google and it will bring up the trans.
Ok I do see what you mean about being the Hyundai numbers for them....but how did you get that number to begin with? Was it through dealer? Did you find it on trans? I just find that info quite useful for future reference... thank for your input
elantra # came from a guy selling his trans the 2000 accent came from my dealer and he checked elantra # as correct,but couldn't cross reference to say it would fit
ah got your dilemma.... Prob is none of the sites I use utilize those type numbers...even for replacement internal parts like rebuild kits. I still don't know how to get those numbers off trans either... like an ID tag or something.
Trans shop should have that type info.... maybe check local shop. I don't even think a yard could help in this situation either...
Discussion Starter · #8 · (Edited)
2000 accent 1.5 mt
shaft assembly 4388022613
bolt 4384628500
pin 4365744000
plate stopper 4391322610
sprig assembly 4384722620
FOR YOUR RECORDS
THESE ARE THE SHIFT ROD GOING INTO TRANS THAT THE CABLES ATTATCH TO AND THE INTERNALS FOR THAT SHAFT INSIDE THE TRANS SO IT WILL SHIFT THE SHIFT FORKS
1 - 8 of 8 Posts
