My 07 SF 3.3 has never had the crankcase ventilation system serviced.
As I understand it, there is no pcv valve. What should I look for or do to be certain the the engine is ventilating properly?
There is a PCV valve on your engine. If you pull the valve from the cover, you should feel vacuum on the loose end with the engine running. Then stick a small wooden dowel or similar into the threaded end to see if the valve moves smoothly.
