hey.. im planning to change from manual to power windows in my Hyundai Accent/Excel 98.. i want to know that can i do it with after market universal power window kit? or I have to buy the OEM for Accent 98?
If you can find the regulator + motor in a scrapyard etc, then you should be able to swap it for what you have. Then you'll have to put in switches, wire it up, etc...
Quickly googled some random conversion kits, and they seem crappy. They keep the crank, so it still spins as the window goes up/down, and who knows if it will even bolt up right?
Pretty sure it wont. Different part #'s. Different door style = different mounting positions probably. (I mean with the right tools and skills, you can make anything work but I doubt its worth the time/effort.)
There are also 2 versions: 3door and 4door, make sure to get the right one.
