Hello,
Today I noticed that the 12 volt power outlets on my 2011 Sonata shutoff when the vehicle shuts off. On my old car the cigarette lighter would shut off, but not the power outlet. Is there anyway to make them stay on when the car shuts off? It is nice to be able to leave my phone in the car to charge.
Thanks.
My 2021 Sonata hybrid does not have a 12 volt lead acid battery as my Prius's had. I miss it.
Instead Hyundai uses a DC to DC converter that takes the high voltage propulsion battery, and drops the voltage down to about 14V. So to protect the only battery in car from over discharge, the hybrid system shuts down after 30 minutes.
With my Prius's, where I had a lead 12 V battery under the hood, during power outages at home, I would turn on the Hybrid system (Which stays on indefinably until the car runs out of gas) turn of all interior loads like lights or fans, the attach to the battery my 1200 watt power inverter. (Only used for my TV, modem/router, and few 6watt LED lamps, ) So, as the 12 volts battery dioschages, the Prius would automatically start the engine and recharge the 12 volt battery. On a few oocasions I would connect my fridge by itself to jolt up some cooling.
I cant do it with the Hyundai because its limited to 180 watts with a 25 amp fuse. And it shuts down after 30 minutes.
