Hello,
I was driving on the Motorway and all of a sudden the car stopped when checked the connecting rod had come off the Engine, and there a big hole.
I always ensure that the Engine Oil is unto the level even then this has happend. The car is only driven for 63000 miles and I did not expect this to happen from a car that is manufactured by one of the best car makers in the world.
Speaking to my mechanic I have been adviced to scrap the car is this correct?
Can Hyundai help me in this regard
Are you the original owner?
I would think that would be covered under the 100k mile warranty.
How is the body of the car? It still might be worth it to buy a used engine and have it installed.
Scott
If it has 63000 miles and the timing belt wasn't changed, it may have broken causing this, plus more damage - at speed, it doesn't take that much to snap a con-rod.
In your position, I would look for a good used motor and I would also ensure that ALL maintenance was done to it before installation, including the timing belt.
QUOTE (Praks gupta @ Oct 24 2010, 12:58 AM) index.php?act=findpost&pid=365755
Hello,
I can happen to any car at anytime. Changing an engine is expensive unless you go the secondhand route. I do like your comment about the best car makers in the world but as a tech Hyundai seem to be going down the Toyota route or were they there already????.
