1 - 1 of 1 Posts
Hi, I am new to the forms and did not look through all the post so hope no one has brought this up.
I have a 2011 Sonata 2.4L with the 6-speed Manual trans. got the car back in Nov of 2017 and ever since I bought it the car in first gear no matter if you are an expert stick driver the car will lurch like a newbie on a clutch. (if you are on perfectly flat ground or downhill it will not lurches if you go easy.) So my question is could this be the clutch? or is this how Hyundais drive? it has almost 120k I believe nothing has been done to the clutch. also if it is the clutch is there a place that makes aftermarket clutch/flywheel?
Thanks for the help hope my question makes sense.
PS. all other gear shift fine.
1 - 1 of 1 Posts
