Problem ..... clutch went straight to the floor board and did not return. some fluid under car after this occured. I can lift clutch by hand but when I try to shift into gear it goes right to the flood again with no resistance. I'll take (tow) to dealer Monday but was just wondering if anyone might know the problem.
thx
You blew the seals on the master or slave cylinder. You probably could fix it at home cheap. Let's see if they'll fix it under warranty.
