2003 Hyundai Tiburon 2.0 5 Speed
I dont know what to do? I have installed a clutch in car before and was fine, I was redoing the timing belt walter pump and thought I would put a new clutch in my car well at it, I got a FXR Stage 2 Clutch and Flywheel on ebay, put in car drove a mile clutch pedal locked up not down, so bleed the slave drove fine for about 100 miles same thing, so put a new slave in drove 2 miles same thing clutch pedal stuck up, so put a new Master and hose from master to slave still locking up, it is not connect to the transmission and it is locking up? any help would be great thanks
Just a quick thought, have you checked the pedal assembly it self. Might be that when you installed the new Clutch kit and were bleed ing the system you might have depressed the pedal too far and either changed the way it sits on the bar or even if there is a shim or sleeve it sits on that may have moved. Hope that this helps
