You can also reach in behind the front wheel and grab the lower end of the skinny vertical bar while a friend rocks the car from side to side. If you feel a knocking in the palm of your hand, congrats, you are the four millionth Hyundai owner to experience a bad sway bar link. Repair cost is zero under warranty, and only slightly more after warranty.Sway bar links is worst offender for noise..
Go out on street or empty parking lot.... roll straight, and at same time,, whip the steering wheel back - forth to rock the front of car,, see if it makes clunk / knock type sound
I got Autozone Duralast links. Lifetime warranty. On my second set (these were free) now.You can also reach in behind the front wheel and grab the lower end of the skinny vertical bar while a friend rocks the car from side to side. If you feel a knocking in the palm of your hand, congrats, you are the four millionth Hyundai owner to experience a bad sway bar link. Repair cost is zero under warranty, and only slightly more after warranty.
:trophy:Apparently the front stabilizer bar links are a "weak link".
Couldn't resist.
