has anyone removed the headlights on this car, and if so, are the low beam lenses removable from the housing? i want to clean the inside of the clear covers. the driver side is getting a bit of a hazed look thats specifically obvious in a 3" circle where the headlight beam is focused.
since i ordered hid lights, i figured this would be the time to try to wipe off the lenses since ill sort of be in there anyway. also im concerned that brighter lights would only amplify the haze.
if you have any knowledge on disassembling the lights, or a good suggestion on what to clean with, id appreciate your input.
thanks!
thanks!
