I broke the mirror on my drivers side sun visor when it accidentally got caught in the window. I bought a used visor from a junk yard. We swapped them out. There was a simple electrical connector. We did not have the key in the ignition when we unplugged and connected the new one. When started the car to test if the light would come on, a chime started and will not quit until the key is removed from the ignition. It continually chimes in ACC mode as well as fully cranked. You can put it in gear and drive off and the chime still goes. There is no light indicating that the doors are open. The chime continues even though all the doors are firmly shut. We disconnected the battery and reconnected. This made no difference. Can someone tell me what might be causing this and what we might could do to fix it?
We swapped back to the old visor and the chime continues.
