So I was having trouble where my 04 Getz wouldn't always detect that the clutch was in when trying to start the car. I bought a new clutch switch ($35AUD), and went to install it today.
I could've fixed this with a piece of gaffa tape ? For some reason there's a hole in the tab on the clutch pedal that lines up exactly over the clutch switch button. I assume there was a plastic clip across it that broke off. I think I remember vacuuming up!
Just posting to save anyone else making the same mistake.
I was called out to a garage the other day to check a Kia Picanto that wouldn't crank. I put a bolt through that hole and had it fixed in 5mins. Dumb mechanic not happy and neither was his boss when I handed him the bill for my callout :laugh:
Makes me feel a little less sheepish! Out of pure curiosity, do you know why that hole is there in the first place?
There's supposed to be a wee rubber pad in it that the switch plunger presses against. I've highlighted the pad for the other clutch switch in your photo....
That bill helps them to learn.....Education is expensive.....so is ignorance...:smile:
