my wife's 2009 Hyundai Sante Fe recently had the check engine light come on. i took it to the nearest autozone to have the code read. It was p0441 (evaporation emission control system incorrect purge flow) i took it to the local mechanic and they were going to charge me $125/hr to diagnose the code. he said that they were going to do a smoke test to find if a leak exist. another symptom is whenever the low fuel light comes on and we fill up the gas tank the car wont start unless you turn the car over for approximately 30 seconds. could the issue be that when we fill up the gas tank that air is getting into the fuel system thus preventing the car from turning over. if i clear the code is usually comes back with 50 miles. any help would be greatful
Replace the Purge control valve and carry on..
I just saved you maybe $125+,, you owe me an order of BW3 wings, medium, basket of fries, and a drink.
It behind the intake near the throttle body. The hose going to the intake will be a pain. 90° needle nose might help, razor blades too.
