My car was parked for 5 days. When I next started it there was no response when I depressed the gas pedal--car remained in a rough idle. Had to restart the car three times before it worked but check engine light has not gone off. Any ideas as to the problem?
1 - Scan
2 - codes found
3 - based on codes found, I can tell you what the repair is
QUOTE (strange @ Oct 26 2010, 09:56 AM) index.php?act=findpost&pid=366380
I had a similar problem with my Azzy and the dealer checked the codes and turned out to be the throttle sensor. Replaced under warranty and everything is working just fine. Get the car to the dealer and I am sure they will find the cause.
Don
QUOTE (dronrs @ Oct 26 2010, 09:47 PM) index.php?act=findpost&pid=366601
Don
Most of the time is the throttle sensor
_____________________________________
Hyundai Philips Lights
