For some reason my 2006 Accent check engine light comes on whenever I drive over 45 miles per hour. I have recently spent so much money on fixing and replacing coils, cracked head gasket and other maintenance. Can't figure out the reason behind this problem. Does anyone have same problem with their Accent? Need your help to fix it. If any geniuses out there that can help me, I would be the happiest person.
Thanks in advance.
I know I aint the brightest bulb on the string, but what codes you have ??
Without that info, you can surely waste a whole lot of time time tossing some really expensive parts at the car as a guessing game, may even make the situation worse..
Yeah a lot more info is needed for us to help you, how many miles do you have on the car? Did you follow all the maintenance for the car? Which one did you missed? When you drive less than 45 miles does the CEL goes off? If not then what's the code? If you don't know how to do that, just take the car to autozone or a local auto parts and let them get you the codes.
