Installed RoadSport Profit mud flaps on my 2010 Santa Fe. I bought them at Canadian Tire for under $20 a pair. You need the #1 fit. Fit is very good. I used the factory screws - never had to drill. Its an option if you don't want to buy the OEMs.
can you tell me the part number / code???
My SF has this elements factory installed, but someone hit it and it`s loose on the interior (I need to guess what is broken , to replace screws or else)
Thanks.
not a fan of those type of mudflaps because the rubber/plastic on outside will rub the paint finish right off the outer paint of the vehicle in no time thus causing even more rusting than w/o them.
I prefer inside flush mounted flaps not overlapping onto the outside just the inside plastic wheel well is all.
Mud flaps...
13 years with the OEM Flaps on my Accent. Hasn't hurt the paint at all. Not the best view I just noticed.
