1 - 10 of 10 Posts
MODERATOR
Hyundai Santa Fe: Transfer Fluid. Repair procedures - Transfer Assembly - 4 Wheel Drive (4WD) System - Hyundai Santa Fe DM 2013-2014 Service Manual
(as per the hyundai repair manual)
Normal Driving Conditions: Changed 40000 miles / 4 year.
Severe driving conditions: Change every 8,000 miles
1. Driving in dusty, rough roads
2. Driving in mountains areas
3. Driving for patrol car, taxi, commercial car or vehicle towing
4. Driving over 170Km/h
5. Transfer oil should be replaced if the transfer assembly is fall into the water.
DIRECTIONS:
  1. Remove the under plastic splash shield cover
  2. Remove the oil filler plug(always do this first, so you know its not seized, and you'll know you can always refill the unit)
  3. Remove the drain plug and let the fluid drain
  4. insert the drain plug (57.9lb-ft)
  5. insert the hose from the refill pump, into the fill port
  6. pump fluid until it comes out of the fill port. (Hypoid gear oil API GL-5, SAE 75W/90)
  7. insert the fill plug (Tightening torque: 43.4lb-ft)
  8. wipe everything down
  9. re-install plastic plash shield cover
Oil capacity :
Diesel 2.0 / 2.2, Gasoline 2.4: About 0.6 L (0.16 U.S.gal., 0.63 U.S.qt, 0.53 Imp.qt.)
Gasoline 3.3: About 0.68 L (0.18 U.S.gal, 0.72 U.S.qt, 0.60 lmp,qt)
Fill Plug: Tightening torque : 39.2~58.8N.m (4.0~6.0kgf.m, 28.9~43.4lb-ft)
Drain Plug
Tightening torque: 58.9~78.5N.m (6.0~8.0kgf.m, 43.4~57.9lb-ft)
(video coming in the spring)
Fill Plug:
Drain plug:
Hey @ImStricken Were you able to make the video? I'm planning on doing this soon. I'd like to watch the video before doing it. I change the ATF on my cars all the time, but for some reason it's more cumbersome on the Hyundais.
MODERATOR
honestly, no. i will soon though. sorry about the delay; just over-loaded with projects.
MODERATOR
i believe ill be finally tackling this job this weekend.
MODERATOR
You have the AWD Santa Fe, right? The 2WD procedure is different. We'll have to make a DIY video for that too.
MODERATOR
Discussion Starter #7
there is no transfercase or differential on a 2wd (fwd)
MODERATOR
Discussion Starter #9
I have 2013 AWD Santa Fe with the 3.3 and there is a down pipe in the way of the fill bolt. Has anyone successfully done this job with this configuration?
I attempted to remove that portion of the exhaust but once unbolted there doesn't seem to be clearance to pull it past the subframe.
1 - 10 of 10 Posts
