I looked on hmaservice.com and I did not find a procedure on how to replace the tranny fluid in my car. I do have a problem when I am driving and the RPM would go to 2000 to 5000 and then go down to 2500. I assume that is transmission slippage, however I have yet to change the fluid. So I just need a DIY on how to do this kind of deal. I'm not looking at a drain and refill. I want to do a tranny flush. Hopefully, someone would be able to help me :). Thanks.
CamronTheGreaat
PS: If you're in Virginia, I'm there! :D
1 - Go to dealer and buy a filter kit (filter and pan gasket) and 6 SP-III ATF
2 - drain atf from pan
3 - remove pan from trans case
4 - change filter
5 - install pan
6 - refill ATF with 4 SP-III
7 - start engine, inspect level in "N"
8 - wait a bit for engine and trans to get warm/hot, finish adjusting ATF to bottom of HOT zone on stick
