Yes.....and MONEY too.Are we just waiting our monkey with synthetic?
I hate auto-correct.Yes.....and MONEY too.
Real synthetics are almost gone and the "new" ones aren't much better than "conventional" in most categories.
Having said that, it is a hard habit to break.
I still use Mobil 1 in everything I own.![]()
I do my own oil changes and only pay 29.58 everytime for Mobil 1 syn extended 5w20 and OEM oil filter.I read thru BITOG some this evening. My GLS is not turbo. My driving is "normal," and most of my miles are highway in St. Louis. For my first year, I've used synthetic, but now, especially after reading some more tonight, I am thinking my Sonata only needs mineral/dino 5w20, w/OCIs of 5,000 mi. BITOG seems to indicate the main advantage for syn to me would be starts under -20 degrees, which we do not get here.
I have my oil changed, so my cost for syn is >$60, and for dino is appx. $20.
I know. There are other oil threads here, but I did not see any that covered my specific concern.
Anyone with further thoughts on this?![]()
Probably some benefit in real cold climate at startup. Beyond that not sure. My neighbor uses Dodge Caravans for his messenger service. Last one he replaced was still running with 375k on the clock, original engine and Supertech conventional oil every 3k religiously. Go figure.I use full synthetic because of the spun bearing issues I keep reading about. Seems like my valves are a bit quieter after cold starts too.
Who said they are "no good" ?So, just out of curiosity, what are your thoughts on current synthetics being no good?
Why are you opting for a 5,000 OCI? Isn't the recommended OCI for the Sonata 2.4L 7,500 for normal driving conditions?I read thru BITOG some this evening. My GLS is not turbo. My driving is "normal," and most of my miles are highway in St. Louis. For my first year, I've used synthetic, but now, especially after reading some more tonight, I am thinking my Sonata only needs mineral/dino 5w20, w/OCIs of 5,000 mi. BITOG seems to indicate the main advantage for syn to me would be starts under -20 degrees, which we do not get here.
I have almost thirty years of 3k/3mo in my blood. I'd want to do a couple of 5k OCIs, then have the oil tested on the second one just to make sure.Why are you opting for a 5,000 OCI? Isn't the recommended OCI for the Sonata 2.4L 7,500 for normal driving conditions?
Good point. By the way, I went to Walmart today, and there's only a $9 diff between dine and synth. How do these oil change shops justify a $30+ upcharge for synth?Who said they are "no good" ?
They are only slightly better than "conventional" formulations and probably not worth the extra money.
For instance, they lack the cold flow advantage of a real synthetic and the exceptional resistance to thermal breakdown too.
Where are you buying your oil and filter? $27 M1 Extended @ WM + $10 for a K&N Gold filter @ Amazon.I read thru BITOG some this evening. My GLS is not turbo. My driving is "normal," and most of my miles are highway in St. Louis. For my first year, I've used synthetic, but now, especially after reading some more tonight, I am thinking my Sonata only needs mineral/dino 5w20, w/OCIs of 5,000 mi. BITOG seems to indicate the main advantage for syn to me would be starts under -20 degrees, which we do not get here.
MO, I thought you were concerned about wasting money!I have almost thirty years of 3k/3mo in my blood. I'd want to do a couple of 5k OCIs, then have the oil tested on the second one just to make sure.
To be honest, I've been using synthetic (valvoline, mobile) for 11 months, and I've yet to go beyond a 6k mi. OCI. That's one of the reasons I am thinking of going straight dine. I feel like I've been wasting my money with synthetic at those OCIs.
That's free market capitalism for you.How do these oil change shops justify a $30+ upcharge for synth?
