Hi all, I had been trying to install a remote locking key on my 2016 i10 S BlueDrive and everything was going well until I noticed about an hour after the install was finished that my hazard lights were flashing. The doors were all unlocked but the central locking no longer worked (each door would lock and unlock from the inside normally but I couldn't hear the actuators working at all). I also have no way of opening the boot now, too. The car turns on and drives as normal, but so far I've noticed a lot of other faults in the system:
I have checked all of the fuses within the fuse box below the steering wheel and in the engine bay with a multimeter set to continuity and have found no breaks. The remote lock install was around the passenger door with all the wiring coming from the loom behind the glove box. The unit itself grounded 2 wires when locked/unlocked, which went to a relay back to the door control wire (I can draw out a basic diagram if anyone needs).
I'm not too sure where to go from here in terms of diagnosis. Is there anything you guys would recommend before I cave and take it to be seen?
- The tail lights do not light up but the brake lights and reversing lights work fine
- The front parking lights do not work (and as a result the center console lights do not turn on and the headunit does not dim when the stalk is turned) but the DRLs and dipped/high beam headlights work fine
- The indicators do not work, same with the hazard lights
- The door open sensor does not seem to be working (no light on the dash, interior light stays on even if doors closed) but the electric windows work fine
