· Registered
Update on my i10
The boot doesn’t unlock like it used to.
It does if I press and hold the boot unlock key button.
The lock feature to stop the access to opening the rear windows also doesn’t work.
So….my faults that happened all of a sudden are….
1. Rear drivers door does not unlock/lock with the central locking (I’ve tried using the key and remote buttons. I have to manually lock the door from the inside with pushing the little switch button by the lever handle.
2. Tailgate does not open with the unlock button like it used to with the other doors. It does unlock if I hold the tailgate button down on the remote. It locks with the key fob.
3. The child safety window button for the rear windows to stop them using the button on the doors does not work either now.
4. When I drive off the car try’s to lock the doors but it makes the lock/unlock noise about 3 or 4 times
All of these faults started yesterday, any idea or advice guys?
· Registered
All of these things have one thing in common. They all operate from the Etacs unit and probably due to a connector not making a good tight connection on the unit.
