My girlfriend's 2015 Santa Fe Sport is showing three yellow lights: ABS, Electronic Stabilization Control, and Downhill Braking Control. Her brake fluid looks to be within range, and the car drives normally. Any ideas?
2013 Hyundai Santa Fe Sport
Problem is with the abs sensor at the wheel. Need to pull tires and verify that the connector is plugged in and no tears to the wires. If the wiring is OK get codes read by dealer or parts store to see which sensor is bad.
Either way should be a quick and relatively cheap repair.
Sent from my SM-G965U1 using Tapatalk
