Recently failed inspection because the catalytic system and o2 sensor are not ready. The shop told me the reason for the system not being ready is due to someone jump started my car and I need to drive another 100 miles to the system to be ready.
I have not jump start my car for the last 400 miles, but I did have my alternator and valve cover gasket replace under warranty, and I have driven 400 miles since then.
Anyone have any idea what's going on? Btw, I'm located in TX.
Removal of power wiped out all stored data in PCM... now need to drive various cycles so the READINESS TESTS complete for you to pass inspection
I did a quick google search, does follow procedure looks like the correct way to complete the readiness test?
The Intake Air Temperature (IAT) should be between 14 and 122 degrees F.
Barometric pressure should be equal to or greater than 75 kPa.
The fuel tank should be between 25 and 75% full at the start of the test.
During acceleration, keep throttle 1⁄4 to 1⁄2 open.
During deceleration, slow to less than 15 mph at an engine speed of less than 1000 rpm without touching the brake or clutch pedal.
During cruise, maintain a steady engine speed between 1400 and 4000 rpm.
At idle speed, keep the throttle closed and the gear selector in the Neutral position. Remember, these are just the preliminary instructions. The actual drive cycle must conform exactly to the following instructions, or the various monitors may not run to completion.
The drive cycle begins with a cold engine startup. The IAT must be between 32 and 85 degrees F. Engine Coolant Temperature (ECT) must be less than 127 degrees F. It may be necessary to leave the car with you overnight so it can cool down completely. The engine coolant and intake air temperatures must be within a tight range to complete all of the OBD II monitors during the drive cycle. If the IAT input is not between 32 and 86 degrees F at the beginning of the drive cycle, the EVAP monitor will not run.
Start the engine and allow it to idle in Park for one to two minutes.
Within the first minute and a half, accelerate at 1⁄4 to 3⁄4 throttle to 50-55 mph. Hold that speed for 2-3 minutes. Unless your shop is very close to a major expressway, it may be difficult to satisfy this step in the drive cycle.
Decelerate to 0 mph without braking, then idle for 1-2 minutes. If you’re on an expressway, pull safely off the road during this segment.
Accelerate to 55 mph, using 1⁄4 to 3⁄4 throttle, then hold a steady cruise for 10 to 20 minutes.
Return to 0 mph with the engine idling in Park, then turn the ignition off.
