I am collecting a 2005 terracan on friday and will use it to tow my twin axle caravan
The handbook says do not use 4wd on dry tarmac but it also says use 4L for vehicle towing
When towing the caravan on dry tarmac do I use 2wd or 4L ?
Hi Michael,
I am assuming that you do not have the Highlander model. Never drive your part time 4wd Terracan in 4wd on any hard surface as the result will be what is called 'wind up' of the drive train. The only time that 4L would be used is if you were attempting to reverse a van on grass/mud/snow etc and needed traction but even then I would be very hesitant.
Hi Michael, I tow an Elddis crusader storm twin axle caravan & have only ever used 2 wheel drive for towing. Have you got the handbook with your Terracan ? Mine has nothing in it about using 4L for towing .
