I hope I am posting in the correct forum. My wife drives a 2005 Hyundai Tucson 4cyl. She has been noticing that her car begins to stall when she turns on the AC. She will also experience a sudden power loss while AC is running and she is driving down the road. With the AC off the car runs great and no noticeable issues. Things I have checked.
1) battery and alternator have both been tested and no issues.
2) I scanned for engine codes and found code P0301 misfire detected in cylinder 1
Could the P0301 be the issue?
What are your thoughts. AC does blows cold.
When I was running tests I put it in neutral and held the RPMs at 2,500 than kicked on the AC. The RPMs dropped to around 600 than slowly started increasing. Maintaining the RPMs I turned the AC off and RPMs immediately went up.
Excessive power draw or failing sensor perhaps? Not sure what to check next. I will be replacing the spark plugs and wires as I know it is due however I’m not sure that is the cause of the AC issue. Thank you all for your advice on this.
