1 - 8 of 8 Posts
I just picked up this 2005 Elantra last month. She runs GREAT - except after filling. Then she will occasionally sputter or sometimes stall during idle. Otherwise, if tank is below 3/4 (approximately), she runs fine. Can you help me out here?
Sounds like the evap solenoid is not working or the gas tank air filter is clogged. May be the evap hoses are kinked or colgged too.
To test leave the cap loose after filling. If it runs OK then the evap system is the problem.
I just checked and that info is there.
Melbourne, Florida - 2005 Hyundai Elantra.
Am I missing something?
Thanks! - I will drive with cap loose and see if it helps.
When you say the "Evap solenoid"...are we talking the one in the Charcoal Canister...or somewhere else?
I have no idea where it is on your car.
Go to www.hyundaitechinfo.com and sign up. You need to use IE and allow popups. It will show you where the solenoid is if you dig deep enough.
Check for codes with scanner first.
Purge valve which can also be called a solenoid; located under hood on back of intake manifold, close to firewall.
You need intake air supply snorkel removed to change part and see it properly.
One 10mm bolt , two tiny hose clamps, one electrical plug held with retaining clip; 15 minutes approx change time.
1 - 8 of 8 Posts
