1 - 10 of 10 Posts
The car wasn't use for two months and when I start the car it works for 15 mins then stall. After that it keep on cranking but won't start, there's spark, there is fuel on injectors and no codes detected by OB2. When I put starting fluid it start for awhile then stall.
Fuel filter and fuel pump already changed, crankshaft position sensor also new
Now my starter was damaged due to frequent cranking
2007 Honda CRV
Spraying starter fluid and the engine started
and ran for a short while means fuel system issue.
First would see if there is injector signal. Last time, I confused spark plugs with injectors.
So may be best to hear this from someone else.
You can put a noid light on the injector connector to see if there is signal
Or try a test light across the terminals. Off when ignition off or key just in on position.
Blinking when the engine is cranking.
If you have injector signal then check to see if there is fuel pressure at the fuel rail.
When changing the fuel pump, some times an O ring isn't installed and there is not enough fuel pressure to start or run the engine.
I already tried putting a noid light and all of the 4 injector harness was blinking when cranks, also cleaned the injectors and test all of them sprays fuel
No fuel pressure test point but when I open the fuel line and switch the ignition there is fuel coming out
What maybe the problem
The problem maybe an exhaust restriction, preventing the engine from breathing. In other words there is not enough oxygen being drawn into the cylinders to allow combustion to take place. You could try removing the upstream O2 sensor from the exhaust to see if that allows the engine to continue running. The hole in the exhaust where the sensor used to be will provide an escape route for the exhaust gas, which will allow the pistons to draw fresh air into the cylinders.
I will remove that O2 sensor and try starting the engine but need to fix my starter first, thanks for the advice
If that's When I put starting fluid it start for awhile then stall.
[QUOTEWhen I put starting fluid it start for awhile then stall. ][/QUOTE] How long did it run on starter fluid?
Do you now have a flat battery or have you burnt the starter motor?
Discussion Starter #8
The starter is fixed and battery charged already but still crank but won't start, when I put starter fluid it will start for a while even i
removed the oxygen sensor as your suggestion
What more should I check? need help
A fuel pressure test would seem to be the next logical step. But that requires specialist equipment. Fuel being pumped to the rail on the engine doesn't necessarily mean the fuel is being pressurised.
Discussion Starter #10
If the fuel pressure is not enough what is the best thing to do?
1 - 10 of 10 Posts
