Hi,
I just bought a fixd sensor to plug into my obd II port , but I can't locate it no matter what I research. I have the sonata 2013. I am not technical as far as taking anything apart, I though it was supposed to be easily accessible. I read something about it being under the steering column, but I don't see it.
Thanks,
Linda
Drivers side, it will be located under the dash about where your left knee would be if you were sitting in the drivers seat.
Mounted to edge of left lower dash panel.. look at bottom of panel,, see matching connector pointing downward to floor...
Will I need to open the fuse box or anything? Or is it out and visible(maybe using a mirror?) Thanks!
I have pic I took yesterday while doing a "fingers" in the steering column,, DLC is installed to the rectangle slot on bracket there
  • Like
Reactions: guidvce
