Whenever I put gas in my car and only at this time after I m done putting gas in and I go to start my car it does not start right away it takes a few tries...every single time. need help?
Discussion Starter #2
I PUT ONE LITER GAS CANNOT START SO GET 2 LITERS THEN NEED THE ACCELERATOR PUSH 3 TIMES DONE....
You are supposed to fill it with DIESEL not gas.
I thought you were answering your own question! It's VERY difficult to figure out what you are trying to convey?
  • Like
Reactions: teezythakidd
2007 Honda CRV
What kind of engine does it have? Gas or diesel?
If it is gas then the purge valve might be stuck open?
Or vent valve is stuck closed and the purge valve leaks??
Who knows for sure?
If you have a gasoline engine, difficulty starting at fill up time is usually a p0441 evaporative purge control valve failure.
Sent from my SM-T510 using Tapatalk
