Hello,
We just purchased a new 2018 Santa Fe XL Limited to replace our 2011 Santa Fe Limited. Can we use the OEM wheels from the 2011 as winter wheels for the 2018?
I want to ensure that the bolt pattern, and offset is the same, and that the old wheels will clear the new brakes.
Here is a picture of the wheel style we have on our 2011:
Here is a picture of the new wheel style on 2018:
Thanks!
The wheel/tire combo is good but the TPMS (if equipped) will be different. On the new '18, about 10 minutes of driving will be all it takes to set the blinkie tire light into action.
You can opt to buy a set of compatible (with the '18) sensors and put them in the old wheels and the car will recognize them and the TPMS will work properly with the winter rubber installed.
My suggestion - Jack the new '18 up, pull one of the wheels off, stand it alongside an old '11 tire/wheel and visually check size, then put the '11 wheel on the car and see if it fits. Shouldn't take more than 15 minutes and it gives you a definite yes/no.
