My 2010 Accent GS (3 door) currently has approximately 1700 miles and I figure I'll be doing my first oil change shortly so a couple questions came to me.
1) What oil filter do you guys use? Cheapest thing you can find, OEM, Fram, etc?
2) I'm toying with the idea of switching to synthetic oil. Do you guys use dino or synthetic? Also, how many miles should I go to "break in" the engine before making the switch if I do?
As I had mentioned above, I have a 2010 Accent GS. So here's a few other questions.
3) Where can I buy a shop manual for this vehicle? Or, where can I gain access to an electronic version of it?
4) Does the GS come with the quick shift kit for the stick (manual transmission)? And if it doesn't, how much shorter of a throw will the short shift kit affect it?
5) Does any manufacturer make a rubber liner for the trunk to help keep dirt and/or mud from wrecking the carpeting?
I appreciate your help.
David
David
