I was installing an HID kit in my car last night and as I was tightening one of the power wires on to the negative battery clamp, the bolt broke off leaving the screw with the square end still in the clamp with no way to tighten it. I have tried taking it out but I am unsuccessful with every attempt. Is there anyway I can file the end of it down and pull it out and replace just that screw that secures the clamp?
I am at work and currently can't take a picture of it but if you were to look at the battery under the hood, it is the bolt that is facing at an angle that looks directly at you on the left of the negative clamp.
It is tightened down enough to drive and it does not come loose at all.
Thanks guys!
Thanks guys!
