Hello, everyone,
My OEM passenger side brake/tail light recently went out. The dealership was going to charge me $30 for a set of OEM replacements, but I declined that.
I had previously received comments that you can barely distinguish the brake from the tail light from other observers. I always wanted to replace them with something better, but waited until they finally gave out. Now that one of them is out, I've received a pair of 1157 brake/tail light bulbs from Auxito. I apologize if this has been done before, but I figured someone might save himself/herself a trip to YouTube by reading this, or if they were curious about the strength of these bulbs.
The installation was very quick (took me less than 3 minutes to swap out the two sides.)
Step 1: Locate access panel in the trunk, turn lock so it faces up/down, or away from you.
Step 2: Carefully remove panel (the door comes off)
Step 3: Locate and twist (counter clock-wise) the bulb that has the orange back plate
Step 4: After a bit of a wiggle, the connector comes out of the tail light housing
Step 5: Gently push and twist on the bulb so it comes out of the orange housing
Step 6: Reverse the process to install the new bulb (Auxito 1157 bulb shown below)
Before swapping both of them out, I wanted to run them side by side to observe the difference. While I wasn't completely blown away (maybe my expectations were not entirely in check,) I could spot a difference (old bulb on the left, new LED bulb on the right.)
I'd say this was the easiest plug and play swap I've ever done, and I am pretty happy with the results.
