1 - 8 of 8 Posts
Hello... So I changed all 3 brake light bulbs and I have checked the fuses, all good, but yet I have no brake lights only, everything else seem to be working. Do you think my problem now is the relay switch by the brake pedal? thanks
Might help to know what you are working on.
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
Check the switch at the pedal.
Thanks. All I know is if I disconnect the connector and loosen the locknut it should come off, Is there any adjustment I need to do with replacing it? Thanks
Discussion Starter #8
That's only in the States and I'm not from there. Also every dealerships I called have to order the part but I got one from Amazon and it was 10 dollars cheaper than the dealership wanted... everything is finally all good now, thanks
1 - 8 of 8 Posts
