Hi!
I bought a hyundai i10 2009 and for some reason all the 3 brake lights will not work. The fuses work, the brake switch also works. The only problem is that there is no power in the brake lights. I have tried everything and am wondering if there are any ideas.
Thanks!
Is there power being supplied to the switch? If there is and the switch works properly then either the bulbs are all blown or there is a break in the wiring between the switch and the lamps.
