I replaced the brake fluid today as it's been two years since the car was new with original fluid. Fluid was dark amber which means it had absorbed moisture, and here in the humid South I have found I need to do this once per year on all my vehicles.
Tried other methods but using a Mityvac fluid extractor is the easiest and cleanest one man way to do it.
However, I could not figure out how to remove the reservoir filter screen from the fill neck, which meant I had to suck all the initial dirty fluid from the right rear wheel caliper, and not directly from the reservoir, so it took a long, long time.
If anyone has found a way to remove the filter screen it would help next time.
