· Registered
Well I paired the phone, downloaded the phonebook but like every 15 minutes it announces connection completed. Not sure if it's the phone confirming or it's the Soanta system.
Phone is not listed as compatible but then again it's a new model phone.
UPDATE: Seems like it wants to download the phonebook is the issue. This only happens when I enter the car and the bluetooth is active on the phone. If I activate bluetooth after the car is started seems like there is no problem. If I get out of the car for some time and then get back in the problem comes back.
I've turned of syncho of my phone with motoblur & google thinking this would help.
· Registered
Drop by the dealer and try it out on another car to see if it will react in the same manner. At work 95% of out phone/car problems end up being non compatible phone software problems. Phones seen to change every 3-6 months and can update change their software at a drop of a hat, but the car not so fast, if at all.
· Registered
Different phones react differently, Mine did that also.
I have a Droid. I posted here and got a great answer ... i had installed it wrong obviously. I followed the directions from someone with the Droid and Viola, My phone works great now....
Check with someone who has your phone working correctly and delete everything, then start over with the way they got it to work......
· Registered
QUOTE (snapper41 @ Jul 10 2010, 10:30 AM) index.php?act=findpost&pid=340517
Ya I did that - same problem. Seems like a compatbility issue. On second entry into the car with bluetooth enabled it just wants to download the phonebook. Called Motorolla but did not get anywhere except "sounds like a capatability issue"
