21 - 36 of 36 Posts
· Registered
Discussion Starter · #21 ·
QUOTE (BigSlick @ Jan 31 2011, 09:17 PM) index.php?act=findpost&pid=396905
My phone is stock, not rooted and yes I've tried that. It pairs and on my phone it shows that its connected for voice and media...then the voice part disappears after a minute or so and it just shows that its connected to media. But it still never plays music through the BT either. When I hit the call button, the radio acts like its gonna download the phonebook but then nothing happens. It's very frustrating, especially when I read about other people having no issues. Maybe there is a difference between NAV and no NAV.
Take it to a dealership and then take YOUR phone and pair it to another car and see if you get the same issue. They should be more than accommodating.
· Registered
QUOTE (Bearcats @ Jan 31 2011, 09:25 PM) index.php?act=findpost&pid=396909
Great idea...don't know why I didn't think to do that.
I'm dropping my car off Thursday ti get some scratches fixed so I'll try to remember to do try it out. I'll keep you posted on the outcome.
· Registered
1) Motorola
2) Backflip
3) Android 2.1 (rooted)
4) Last name first for voice activated calls, media streaming works, but no control with any buttons on the head unit.
4) 2011 Sonata Limited
5) Dimension audio, no nav.
· Registered
Ok so I dropped my car off tonight and got my rental GLS and it does the same thing. Gonna try to ask someone tomorrow when I get mine back.
· Registered
Discussion Starter · #27 ·
QUOTE (BigSlick @ Feb 3 2011, 09:46 PM) index.php?act=findpost&pid=398170
Hmmm. That's a good idea to start, not sure you'll get much help.
My next step would be to take the car to a Verizon store and see if another phone does the same thing. My Incredible has an issue with hidden networks. Other guys can see them but my phone wont. So it could be the phone too.
· Registered
2011 Hyundai Sonata Limited w/Nav Dimensions
1) Blackberry Tour 9630 Works flawlessly
2) Blackberry Pearl 8230 Works flawlessly
3) Blackberry Torch 9800 does not always coonect, hit or miss
P.S. went into the phone bluetooth device properties and unchecked the Encryption control and it has worked liked a charm.
· Registered
2011 Sonata 2.4L Limited
Dimension audio / no Nav
T-Mobile Blackberry 8900 (tried the latest "official" OS as well as the latest 4 "leaked" OS versions)
Pairs and connects quickly
Transfers 500+ contacts very quickly -- but backwards: Last Name / First Name
Streaming works
Incoming calls work fine
Outgoing: I can only initiate from the phone:
-- voice dialing via the car is totally non-functional
The car mispronounces (and, similarly, doesn't recognize) the names, first/last, last/first, etc.
· Registered
I have the T-Mobile G2 (made by HTC) and it works well. My car is an SE with Nav. The phone is running the stock 2.2 Android OS and is not rooted.
Occasionally, the Bluetooth wont pair, but I just disable it on the phone and re-enable and that fixes it. I would say maybe one out of every 10 times I get into the car it doesn't pair.
I stream audio from Winamp and Pandora to the car and am very happy with the sound quality. The track skip button on the steering wheel even works, although the display on the Nav will not display what song is playing (I dont think thats possible through Bluetooth anyway).
· Registered
QUOTE (Mike Eckman @ Feb 19 2011, 01:08 PM) index.php?act=findpost&pid=404168
Mike -- does this combination get you proper First Name / Last Name dialing? Or do you have to Call "last name" "first name" to get it to work?
- Jon
· Registered
QUOTE (ONNFIRE @ Feb 4 2011, 02:36 PM) index.php?act=findpost&pid=398379
When you say "flawlessly", does this include being able to voice dial with First Name / Last Name? or do you still have say the last name first?
Also: do you know what firmware versions you have in the Blackberry's?
- Jon
· Registered
BTW: if you follow TSB 10-BE-013, you can find out which version of the Bluetooth software your car's audio system is running. I just learned that mind has 3.12.2 in it -- which may the reason voice dialing doesn't work with my Blackberry 8900.
If you would be willing to find the TSB on hmaservice.com and check your BT version and add to your post here, it will help us understand the compatibility issues that much better.
- Jon
· Registered
I just bought a 2.0T WITHOUT NAV and am having problems with my HTC Droid Incredible that are similar to those reported by other users on this forum. The phone pairs Ok, and acts like it is downloading the phonebook but after a few seconds it stops and there are no phonebook entries available through the Hyundai Bluetooth interface. Even worse, I can't add entries by voice through the Sonata bluetooth. The Sonata prompts for all the entry info and says that it has been stored, but there are no phonebook entries available when I finish. The only thing the HTC will do is answer incoming calls and manually voice-dial outgoing calls when I speak the phone number - Not an acceptable solution. I went through the phonebook entry exercise with a cheap Samsung (non "smart" phone) and the Sonata bluetooth interface stored phonebook entries for this phone with no problem, and I could dial by saying the Voicetag name. The Google Navigation APP that gives turn-by-turn directions does not function over Bluetooth with this phone either. (I haven't tried using an audio cable, but that is definitely not an elegant solution.)
The problem is definitely with the HTC Incredible. Mine was purchased through Verizon before I bought the Sonata and they (Verizon and HTC) are providing absolutely no no help in resolving the problem. The Verizon sales rep checked the Hyundai web site and said the phone was NOT on the Hyundai compatibility list. HTC is virtually the only well-known brand that is NOT on Hyundai's list. (I suppose Verizon's solution is to keep the phone and look for a compatible car!)
My conclusion is that the problem is primarily with HTC. There are MANY posts on the internet about the HTC Incredible and EVO running Android 2.2 having an "incomplete Bluetooth stack," which severely limits functionality of these phones on many cars (including Hyundai, Toyota, Mercedes, Lexus, and others). The fact that some Sonata owners with NAV systems are having better luck offers hope that there may be some hope for getting this phone to work. As far as HTC and Verizon are concerned, let the buyer beware, and don't expect any technical support with this problem. Verizon would not even consider exchanging the phone for one that works and breaking a two-year contract is not an option for me.
Has anyone without built-in Navigation found a solution to this problem that does not involve rooting the phone?
· Registered
HTC HD2 with Magldr and an Android Gingerbread Rom, which includes root. Everything works the way it should. It pairs fine, it syncs the phonebook, streams audio via bluetooth. :thumbsup:
If it's indeed a software issue on your Incredible, go to this site: www.xda-developers.com - You can flash all sorts of custom roms that update your phone way before carriers release official updates. They might even have a Gingerbread rom for you.
· Registered
previous phone was BB8530 i think (given to me at work). worked, read: paired, about 70% of the time. i usually had to un-sync, then re-sync and it would work normally. ditched that phone about 45 days ago and got:
LG Optimus S
android 2.2 i think....maybe 2.1.
not rooted because i don't have a clue as to what that is.
it has NOT failed me yet. phonebook downloads, pairs (when i have the blue tooth on). if i forget to turn on the phone's bluetooth and i drive for few minutes, it won't sync when i turn the phone's system on. that is when i hit the voice command button on the wheel, and say 'bluetooth on'. the little lady repeats what i say and in matter of seconds, my phone is synced with car.
audio streams as well, but not near as clear as the flash drive.
21 - 36 of 36 Posts
