2018 Sonata Limited 2.0T (Mfg:11/09/17)
Has anyone found blue LED bulbs to replace the 2018's original LED dome lamp bulbs (p/n 92879-A4000)?
They're 6461 or 36mm. Just Google 6461 LED or 36mm LED and you'll find tons of listings.
I'll warn you though, BLUE (particularly darker blue) is a painful light to have for dome/map lights at night. It'll screw your eyes.
The ones overhead the center console or the ones under the sun visors? The front 2 bulbs above the console are not the same bulbs as 2015-2017 models. I'll double check mine and see what they are. I have white LED's but can say no doubt they are not the usual bulbs (36mm or 6461). Pop the bulb cover off and you'll see.
Might've been for the models with a sunroof. Idunno. But I'm seeing now that they're T10/T15 or 194 for non-sunroof models (Sport for sure and SE? I'm still learning Hyundai's methods lol)
The 2018 console LED's are a twist-in cap from the back side of the console (like the old dash lamps used to be).
They are definitely not the standard barrel bulbs like the vanity lamp and back cabin bulbs, especially at the going price of $68.97 per bulb.:surprise:
  • Like
Reactions: teezythakidd
