Recently I had some "general" issues with my Terracan, probably unrelated from what I will be working with now.
I have replaced the evaporator, actuator temp door due to motor failure, and I am just about to replace the compressor due to clutch failure.
Two injectors have also been replaced due to shudder in the entire car with a following halting and excessive black smoke. Now the car is running almost smooth (I will replace the last injectors to get a continuously idle with no shudder).
MY CURRENT ISSUE
The blower motor is not starting when I activate the A/C control module.
I can exclude the transistor, high blower relay, blower motor, and probably the fuses (But I need to recheck fuse 7 and 25) in the passenger comp. box.
Have anyone had the same experience, and did you solve it somehow? I suspect the issue might be the blower relay or maybe a loose connection. Can anyone please help me describe where to locate it?
Thanks in advance guys!
Just figured out that the relay was broken, and I have taken it out and waiting for a replacement.
