Hello,
So, when I'm driving in rain (real rain, not drizzle or road spray) and the Blind Spot Detection system is activated, it gives a visual and audio warning that it is inoperative. The message can not be deleted unless the car is turned off. Anyone else finding this? Where is the sensor for the BSD?
Thanks,
Jeff
2 BSD unit,, LR & RR
1 is master, 2nd is slave
Scan for codes, go from there
Yes, that's noted in the manual. I've had it happen in heavy rain and also in wet snow. After I cleared the rain it reset itself about ten minutes later. If the sensor, which I believe is on the rear bumper, is covered with slush you'll need to wipe it off.
You are correct. According to the Clilton on-line library, there are two radar sensors for blind spot detection in the rear bump.
You are correct. According to the Clilton on-line library, there are two radar sensors for blind spot detection in the rear bump area.
Interestingly, that's a reason why repair costs are higher on new cars. Even a low-speed hit to either bumper, one that leaves no traces, can damage a thousand dollars of electronics.
