Hey folks,
I have a 2018 Tucson Limited and I started to swap for LEDs on the license plate and internal map/dome lights. The map lights were fine (haven't gotten to the license plate markers yet), but the dome light in the backseat apparently I bought the wrong bulb, heard a weird noise then the lights shut off. Blew the 10a, had a spare and put the stock dome back in and things lit up after replacing the fuse.
For whatever lame reason my dealer still has not given me an owners manual so I'm trying to find what size dome light I should be getting for an LED swap. I see them listed as mini dome light but I'm not sure if there's a specific bulb size. I don't want to keep blowing fuses or buying the wrong bulbs.
Any help is appreciated!
Thanks in advance!
2007 Honda CRV
If you can take the old bulb out, can you read the numbers on the bulb?
That might tell you the bulb part number.
Then, it becomes a matter of matching the part number of the bulb and the LED equivalent
Good luck getting the Owner's Manual from the dealer
