Well I changed the brake pads all around! On the left rear, i disconnected the brake line(for reason I wont go into) and when I reconnected the line I tried to bleed out the air! Well we pumped and pumped, finally got some air out! The problem is we thought we had all the air out but I guess we didnt because the pedal was still spongy. After dealing with this problem I was told to bleed the closest caliper to the master cylinder first and work away to the farthest! Is this true? I always heard to start with the farthest from the MC and work your way in? Can someone please help me with this? Thanks
Pressure bleed !! Blow the old oil almost out of bottle, fill with fresh clean and do a wheel till fresh clear oil seen --. STOP, refill, do next wheel, refill, and so forht.... then the flapping pressure from pumping pedal wont make mess of situation.
Pressure bleeding, I do LF, RF, RR, LR....
